temporary dimension font size
3 REPLIES 3
dnewman
268 Views, 3 Replies
Is there any way to increase the font size for temporary dimensions in Revit? The temporary dimensions on my students' computers are so small we can't read them. For some reason, the same dimensions on my computer are much larger.
3 REPLIES 3
in reply to: dnewman
look for them in the small window on the options bar, they are much clearer
there.
wrote in message news:5166036@discussion.autodesk.com...
much larger.
melarch
What small window on the Option bar? I have not found a method to change the size of the temporary dimension font sizes from release 4.5 to the current release 9.0. There is no display for the values in a temporary dimension on the option bar or the status bar below.
Could you include a picture with your post reply indicating where in Revit's interface or on the Option bar you can see the value for a temporary dimensions value other than on the screen.
In answer to the original question, Why are some temporary dimensions text values displayed larger, probably because the monitor size is larger or the screen resolution is set to a lower DPI value (i.e. 1024X768 VS 1280X1024.
Mel Persin, AIA
only when uisng the Measure tool does the value show up in the options bar.
wrote in message news:5166942@discussion.autodesk.com...
Mel Persin, AIA
