Template
2 REPLIES 2
288 Views, 2 Replies
Template
There's no default templates when I open Revit, it only gives me the NONE option.  Where can I get them?
Tags (1)
2 REPLIES 2
LisaDrago
What version of Revit are you using?
When you look here: C:\ProgramData\Autodesk\RVT 2014\Templates
You don't have any folders for imperial or metric?
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
You can't think AutoCAD and run Revit.
Email: LisaDragoEE@gmail.com
dimiterh
in reply to: LisaDrago
I installed Revit 2014 yesterday and I have exactly the same problem, also I can't seem to find families. There is no Templates folder in the directory you suggested.
