this issue is still persistent in Revit Arch. 2013. This is five years after the original thread.
I know this question is quite pointless, but what is the rational behind taking off the type comment parameter from the repeating detail family? And what about the keynote parameter? Why would that be taken away from the repeating detail family?
As previously noted, some users try to use Revit in the most BIM effective way, and these little quirks disseminated here and there within the program constantly fight back the effort.
Thank you
regards
Talk about one step forward and 2 steps back.
The part I don't understand is that the repeating detail family is clearly taking the info from the original family, do why not bring in the parameters within the family as well?
15 years later and we are still unable to use a Detail Tag on a Repeating Detail Item that is using a single Detail Item spread across a set distance. Instead, we have programmers working diligently on creating Dark Themes and other non-productive tasks while glaring deficiencies continue to be overlooked.
@eblackburnEFFVJ There are people learning how to use Revit who are younger than this thread!
I have discovered that if you create a Detail Item that is line based and uses a nested detail item in a parametric array, it can accomplish the same thing as a repeating detail item and be taggable. The trick is in creating an adjustable end piece to fill the void with a partial item so you're not left with a blank space because there isn't room for a whole element. This is an advanced technique, but entirely possible.
