Hi!
In a text written with the TEXT command, there are two blue fill dots to adjust its frame. In a TAG, these blue fill dots only appear when I edit the family. After the TAG is load in to the project, I can not change the text frame. This is very annoying because some texts are larger than the frame of the TAG.
Can I make a TAG family that I can adjust the size of the text frame, after it is inserted in the project?
Thanks.
Marcelo
Solved by ryan.duell. Go to Solution.
The text note border is only accessible when editing the family. If you run into text that becomes larger than the border, and find it being wrapped to a second row, I would edit the family and add some additional space with the border by making it larger than needed. Unfortunately there is no way to adjust this in the project environment.
Thank you,
