In every project there's a special floorplan where I need to TAG the sill height and head height of each window. I'm attaching the tag file.
Unfortunately I have come to a dead end when curtain walls are used because Revit categorizes them as walls rather than windows. I haven´t yet found out how to tag these parameters in curtain walls, there must be a way but I've tried for days and given up. Any ideas? Thanks in advance.
Wow, let me try this, (openings) it makes sense!!
Yes there are some situations where I'd rather embed a curtain system for larger spans where the modules have to be adjusted as the projects evolve.
About the base offset + unconnected height instance parameters, would you know how to report them in a tag?
So anyone knows how to tag "Base offset" and "Unconnected height" instance parameters in curtain walls?
