Welcome to Autodeskā€™s Revit Architecture Forums. Share your knowledge, ask questions, and explore popular Revit Architecture topics.
Showing results forĀ
Did you mean:Ā
Tag sill and head height of curtain walls
3 REPLIES 3
Eduardo2012
1335 Views, 3 Replies
In every project there's a special floorplan where I need to TAG the sill height and head height of each window. I'm attaching the tag file.
Unfortunately I have come to a dead end when curtain walls are used because Revit categorizes them as walls rather than windows. I havenĀ“t yet found out how to tag these parameters in curtain walls, there must be a way but I've tried for days and given up. Any ideas? Thanks in advance.
3 REPLIES 3
maciejwypych
in reply to: Eduardo2012
I'm guessing that you use the curtain walls as a more flexible tool to design windows?
You can only schedule these values with using a calculated value for the head height (Base offset + Unconnected Height).
The only workaround I can think of, is to use windows with openings only to create openings in walls where your curtain walls area and tag these.
(change the width & height in the window family to instance parameters to speed up the process)
Eduardo2012
in reply to: maciejwypych
Wow, let me try this, (openings) it makes sense!!
Yes there are some situations where I'd rather embed a curtain system for larger spans where the modules have to be adjusted as the projects evolve.
About the base offset + unconnected height instance parameters, would you know how to report them in a tag?
Eduardo2012
So anyone knows how to tag "Base offset" and "Unconnected height" instance parameters in curtain walls?
Rail Community
