Hi I have a u-shape winder staircase using 'System Family Railing' with balusters on the inside edge and I want to keep the balusters on the steps only (refer to pdf attachment).
My question is how do I remove the baluster from the balcony only while keeping a continious handrail and how do i make the handrail curve appear solid.
Thankyou
If I understood you correctly, you want only railing on the landings?
In that case make separate railing on the landing consisting only of one top rail.
For connection between those top rails, I would use separate family or model in place > railing > sweep
Or maybe adjusting these options (in Railing Edit Type) can help you:
