Hello!
Now is the pattern problem in hands! 😞
I try to attach patterns to wall: Materials, Cut pattern, New, Drafting pattern, Custom, Import:
And path: C/Program files/Autodesk/Revit Architecture 2011/Data
And there: Revit.pat (or any other *.pat file that I have).
And there it comes: An error! Syntax error in line 2 or 12 or 10 ???
What has happened? Before I was managed to attach patterns ok. To an other project I mean.
Where on earth is the problem? In the project? The whole program? In the pattern file?
Thank you if you can help me!
Matti Kettunen 🙂
