Sweep separation
1 REPLY 1
B.Pascall
222 Views, 1 Reply
Sweep separation
Is there any way to separate a sweep into all its adjoining pieces? I really want to get all the pieces and their miter angles in order to dimension properly, in order to make an assemble manual.
Brent
Tags (1)
1 REPLY 1
loboarch
in reply to: B.Pascall
You can select just the sweep and create an assembly out of it. Then you could make assembly views from that whihc might help in what you are trying to do by at least isolating the sweep. It does not allow you to select individual segments of the sweep.
Jeff Hanson
Principal Content Experience Designer
Revit Help |
