how to sweeep in revt furniture Family templete using 2d sketch path.please see my attachment and guide me how to create same chair?
Solved by constantin.stroescu. Go to Solution.
in Furniture Family Editor:
Your Name
hi Constantin,
is there any way to create a 2d sketch path and create a circle then use sweep in furniture family templete.
if you want to create a sweep on a 2d sketch pathe the problem becomes more simple:
(on the first drawn segment you will see a mark ..that is the plane (perpendicular on path) on wich the profile will be placed....)
Your Name
Dear Constantin,
I appriciate your reply.thank u so much.i feel its more esay and understood solution for chair sweep.can i have yur direct contact where i post my mail if requried?
