SURVEYOR BOUNDRY LINE, CAD SPLINE TO POLYLINE
2 REPLIES 2
534 Views, 2 Replies
The surveyor's CAD file includes a boundary line that is mostly curves.  It's drawn as a spline.  I'm trying to create a PROPERTY LINE in Revit. I've converted the spline to a polyline in CAD.  In Revit, PROPERTY LINE sketch mode, I can hghlight the polyline but can't select what I've highlights.  Only one of the polylines gets selected.  So I have to try to select them all one at a time.  Any suggestions to converting a spline to polyline in CAD for use in REVIT?
2 REPLIES 2
LisaDrago
I need a little more info... you are in the property line command in Revit. once in the sketch mode - you are trying to select the AutoCAD line as a reference to create the propertly line?
As you are working in skech mode you can select the lines one at a time?
LD
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
You can't think AutoCAD and run Revit.
Email: LisaDragoEE@gmail.com
in reply to: LisaDrago
Thanks for the reply.
Yes, when working in Property Line sketch mode I can select segments of the polyline one at a time.  I can use the tab key to highlight all of the connected segments in the polyline but when I then go to select it only one of the highlighted segments is actually selected.
Keep in mind the history of the polyline I'm working with.  It came from a surveyor.  I don't know what software they used.  It might have been translated to AutoCAD.  It was originally a spline and I converted it to a polyline.  I've tried to work with both the spline and the polyline and both are problematic.
My guess is there is some incompatibility between splines and or polylines in Revit.  I'm curious if others have had similar experience.
