I've created a family for a column with a stone base. The stone surface pattern displays OK in the .RFA family file... However, once loaded into my project it is not visible. I've right clicked and checked the object and surface pattern visibility is turned on, yet not showing. Any ideas?
Well, I changed the patter to a default one and it worked... Anyone know of a good mountain ledger stone pattern that will work with revit?
