surface fill
2 REPLIES 2
182 Views, 2 Replies
surface fill
Hello -
I have a surface pattern that shows and prints correctly at 1/4 scale. When I change to 3/16 scale the fill is gone. I would like to know how to get this pattern to show at all scales. Thanks!
2 REPLIES 2
Is it a model pattern or drafting? Model patterns are for surfaces, drafting for cut patterns. Surface patterns are a real world size, ie a brick pattern regardless of scale will be real size so on a very small scale they would be a solid blob so revit turns them off or to a solid grey tone. Drafting patterns are a set print size, ie a cross hatch set to 1/16th in spacing will print lines that when measured on paper are allways 1/16th regardless of scale.
thanks - I'll rework things using your input.
