Hi
How useful is the option Suppress spaces?
Solved by CoreyDaun. Go to Solution.
That setting will suppress the spaces between things like the data and any prefix or suffix assigned to the dimension, but it will not suppress the spaces within the data; that is controlled under "Units Format".
Thank you very much for your valuable help .
Good luck to you, I always....
