Hello there,
I have recently encounter a problem with sun path while using Revit 2015. There are two sun paths in a single file. I can't remember how the second sun path was invented. There is a possibility that while importing other Revit files to the current file the second sun path was imported. However, i can't remove it. i have deleted all the linked files but the second sun path still remains there. The second sun path does not respond to size changes.
What will be the possible solution to this peculiar problem?
Regards
Shaikh Rahman
