Revit Architecture
Active Contributor
martysaid2009
Message 1 of 2 (188 Views)
Suggested approach to modelling
188 Views, 1 Replies
08-20-2012 02:40 AM
Hi there
I have this curved stairway (jpeg attached) that I would like to model and add to a project in revit (including the railing to the left of the elevation).
I'm completely fresh to modeling in revit - is this something that can be modeled free form or is the process of creating various families required? Any recommended tutorials on this area would be great.
Thanks for your help
M
Marty Said
Revit Architecture 2014
Alfredo_Medina
Message 2 of 2 (161 Views)
Re: Suggested approach to modelling
08-20-2012 07:45 AM in reply to: martysaid2009
  • Draw the plan view of the stair with detail lines, exactly as in your sketch.
  • Start the stair tool (by sketch), duplicate type, set up type properties, etc.
  • Set up the instance properties of the stair ( from level, to level, etc.)
  • Use the Boundary tool > pick lines, and select the two lines that represent the stringers / edges of the stair.
  • Use the Riser tool > pick lines, and select all the detail lines that represent the risers,one by one.
  • Finish sketch.
  • If necessary, use the flip control of the stairs to correct the up/down direction.
Planta1 Revit Online Consulting | info@planta1.com | my Twitter | The Planta1 Blog
