Welcome to Autodeskā€™s Revit Architecture Forums. Share your knowledge, ask questions, and explore popular Revit Architecture topics.
Showing results forĀ
ShowĀ Ā onlyĀ  | Search instead forĀ
Did you mean:Ā
Student Revit Architecture 2012 - no library item available
10 REPLIES 10
Message 1 of 11
kobe
1156 Views, 10 Replies
I have the 2012 student version of revit arcitecture and i have no library items, Walss, doors, windows, how do i get access to these items, itried contacting customer support, but they said as it is a student licence they can not help me and to try the discussion boards????
Someone please help me?
10 REPLIES 10
Message 2 of 11
vector2
in reply to: kobe
I think that content is included with the product install.
Have you checked C Drive>ProgramData>Autodesk>RAC 2012>Libraries?
Message 3 of 11
kobe
in reply to: kobe
Thank you for your reply.
I have been through all the folders in the Revit file and there is none that say libraries. Plus when i try to open up a library item, it comes up with nothing available, doesn't even go to a library file?????
Any other ideas?
Message 4 of 11
vector2
in reply to: kobe
"I have been through all the folders in the Revit file and there is none that say libraries."
Is this where you went?
Message 5 of 11
kobe
in reply to: kobe
Yes the folder wasn't RAC2012 but longer recut architecture.... There was not folder in any of the sub folders called libraries...
Message 6 of 11
vector2
in reply to: kobe
Could you click on your "local disk C" and then
Alt+Printscreen and post that image here?
Message 7 of 11
kobe
in reply to: kobe
I pressed ALT print Screen but it does nothing, do you have any more instructions..... Thanks
Message 8 of 11
vector2
in reply to: kobe
Press Alt+Printscreen then open Paint and click paste then save as
to the desktop and post that here.
Message 9 of 11
kobe
in reply to: vector2
Thank you
Here is what you asked for i hope...
Message 10 of 11
kobe
in reply to: kobe
I just found the library folder, but it is definately empty, i have attached a screenshot.
Message 11 of 11
vector2
in reply to: kobe
Not so easy solution on this one for me, but try this:
(Also the australian way of approaching the same
thing is just different enough to throw me off track
sometimes).
Go to the control panel to Programs and Features and
choose Uninstall/Change for Revit 2012 to modify, and
then choose to Add or Remove Features, then choose
the content you need installed. (Don't know if that will
do it for you though).
I knew they changed the content loader for 2012 but I
never paid much attention to it because I just let it
download the content and then I copied it all to a
secondary drive and I will always have it.
Also keep in mind that the 2011 content is virtually the
same as 2012, in case you come across that stuff too.
