Student copying
9 REPLIES 9
Message 1 of 10
1353 Views, 9 Replies
Student copying
Is ther a way to determine if a student has copyied a file in Revit as opposed to doing his own work?
9 REPLIES 9
Message 2 of 10
BalajiHTI
You can see the File history from Collaborate Tab so you will know how the file is incrementally saved from time to time and by which user.
Show File History
Message 3 of 10
loboarch
You could compare the Element IDs of the same elements in 2 projects. If they have the same element ID then one is a literal copy of the other file. If they have different Element ID numbers then you know both files are unique at least as far as the authorship.
This however would not reveal if an element was cut/copied from one file and pasted into another.  In that case the act of pasting would assign a new element ID.
Jeff Hanson
Principal Content Experience Designer
Revit Help |
Message 4 of 10
in reply to: loboarch
Where do I locate the element ID's?
Message 5 of 10
Thankyou.  This is very helpful
Message 6 of 10
Found it.
Message 7 of 10
I have a student that has saved his revit NER project as a Central Model.  How can that Central Model status be undone so that it is simply a revit file?
Message 8 of 10
loboarch
They need to disable worksets.  That will change the file back to a "normal" file.
http://help.autodesk.com/view/RVT/2015/ENU/?guid=GUID-6A3C4C65-ED01-4F73-8F7E-5D63F205CF9B
Jeff Hanson
Revit Help |
Message 9 of 10
suhaizam
where i can see the file ID sir
Message 10 of 10
Mike.FORM
Select an item and the 'IDs of Selection' will become clickable in the Manage Tab.
