Stuck inside a Sheet Template Schedule Editor
3 REPLIES 3
nikana2000
672 Views, 3 Replies
In customizing a sheet template, I entered into a "Schedule: Revision Schedule".  I made the minor adjustments, but can not get back to the sheet template.
The 'Project Browser' only has "Schedules" under 'Views'.  (refer to attached image)
 I know the rest of the content from the sheet (eg. titleblock) are still in the file, as it still is present when I "Load into Project".
How do you exit the schedule editor from a sheet template file?
3 REPLIES 3
nikana2000
in reply to: nikana2000
Also, closing the file and reopening it brings me back the the Schedule editor.
(I don't believe I have the option to select what view should be displayed when opening the file.)
peterjegan
Try double-clicking on the dash underneath "Sheets (all)"
Or Right-Click on the dash and select "Open"
Or Close the Schedule View.
All three of these actions send me back to the titleblock.
nikana2000
in reply to: peterjegan
Thank you Peter.
I figured it had to so with the nameless blank, but didn't realize it had to be the hyphen itself.
