i installed revit architecture and when its stars up i can only use it in veiwer mode how can get around this
the only time i have ever seen it in viewer mode is when it is on a trial version and the 30days has expired... I assume your seat is licensed? it is network or standalone?
LD
I am a student so I down loaded it through autodesk I assume that this is not a trail version, it was downloaded as stand alone
you got a serial number and all put in as you installed it?
what does your license info say?
Did you activate it?
image for reference...
LD
Under the application menu (Big R in the upper left corner). In the menu there should be license information - then in the flyout of that there is your license information.
IF you can find it there - go to the upper right corner with the ? In a circle - to the right is a down arrow - go to the about. That will bring up your product info and on there there should be a button to get to your license info.
LD
