I'm currently in a drawing in Revit 2012 and can not exit "modify: mode. The ribbon does not display the checkmark or "X" to exit. I've cycled through different ribbons but can't exit.
Donald
Solved by matt.lawrence.2545. Go to Solution.
See that your Revit 2012 is up to date with service pack2 and also has the hotfix
The communication center states that my software is up to date, any other suggests? The problem only occurs in one project file.
I appreciate the assistance.
Thanks, that was easy enough, still stuck in the mode in the one file fthough, I'll try going back a couple backups to see if I can get out.
much apprciate the information.
having a similiar problem in edit mode, with revit 2015, esc or modiydoes not cancel the action or let me out, have to save and close and reopen, anyone have afix?
Michael
@dalameida wrote:I'm currently in a drawing in Revit 2012 and can not exit "modify: mode. The ribbon does not display the checkmark or "X" to exit. I've cycled through different ribbons but can't exit.
Donald
Michael
This happens to me about once in awhile in revit 2015. If it is a central model, I've been able to get out of the edit mode by trying the "synchronize now" button. An error appears that synchronization isn't allow when you are in edit mode, then like magic the X and checkmark options come back to close the edit session.
Just experienced this as well when trying to copy/monitor from a linked file. The synchronize now option was unavailable, but I was able to use the undo arrows at the top ribbon to exit out of the edit mode.
Or you can assign a keyboard shortcut to the command and type it in to finish it when you are stuck in Edit mode.
save the project and it will save it as it was before u entered into the editing. once saved the finish tick and cross re appear
