Volume is automatic in a structural member. From there you can calculate the
mass (weight) either directly in the schedule using a calculated field - or
add this math to the family as a shared parameter.
wrote in message news:4954773@discussion.autodesk.com...
Is there a way to extract this value automatically in the schedule?
Or do I have to create my own parameter with the required formula?
What if the structural profile area is changing?
Do I have to manually recalculate the weight of the beam/column?
I see that the volume can be extracted by the software.
Any help please?
Thank you,
Florin
