Structural Slab Tag Parameter
2 REPLIES 2
647 Views, 2 Replies
question...how to make Structural Slab TAG?...thank you very much...
all I can see was structural foundation structural columns and framing
i hope somebody can help..tia
then if i try to make them...i can't find a label or parameter on determining its thickness...T_T
2 REPLIES 2
LisaDrago
For what you are looking for - is there a parameter for it already?
If so - you can create a tag with that specific parameter - using a label - with it.
You would create a new tag - specify the category it belongs to - then create the label and choose the parameter it needs to read. Put in any lines representing the box or design of the tag and then save it and import it.
LD
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
You can't think AutoCAD and run Revit.
Email: LisaDragoEE@gmail.com
one thing that concerns me is that...
i try to tag it as a family structural framing...because there are no other family for these types of components..T_T
im in a japanese company and we were thinking if we could request autodesk for a GUID to refer the beam's thickness
and elevation or level height...
we are currently working on templates..that is why..anyway thank you very much...
