Here is a tricky one,
Structural link, all settings governed by host view. View range cutting right at 4'. Everything cuts but the structural framing. The cut should appear somewhere within the wall, but instead the geometry does not cut, I went into the structural model and the same thing was happening. I went into the family and toggled visibility settings and symbolic representation and the solution is all or nothing. I either I get the whole beam or nothing at all. I think the issue is cutting the angled beam. I know I can turn the geometry off by detail view settings but I would really like to represent this framing as an accurate slice. Any thoughts? Anything to try?
Jamie Farrell
Solved by ToanDN. Go to Solution.
I ran into this problem before. I had to edit the structural framing family and uncheck the 'Show family pre-cut in plan view' box.
