Could you please help me solving the wall and structural column problem as in the attached file?
i want to create nor a square neither a rectangular column. Can i strech one side of the column?
Thank you.
Solved by AJA14. Go to Solution.
Hi. You have three options.
1- Change the join between the two walls to align with the column using the square off joint.
2- Create a loadable family that can have any alignment as needed.
3- Create an in-place column as you would need. (Preferrable method).
If this solves your problem, please Accepth As Solution to help others.
