This is a little hard to explain but the last week or so the ribbon has been acting strange. One example is when creating a sweep the ribbon will not show the mode options to accept or discard changes while creating the sweep path. I have to cycle the ribbon display options to show the X and check options to complete the sweep path. This is only one example of many different odd things happening.
Sometimes when I am simply drawing model lines the selection options for rectangle, circle etc do not appear until I cycle the ribbon display options. This only started in the last week or two.
I will post some screen shots of the problem.
Has anyone else experienced this?
Solved by DParkGForce. Go to Solution.
OK this is driving me freaking crazy. The ribbon is not switching options at all untill I cycle it. I have to cycle the ribbon display at every step of a command. Making a sweep means I have to cycle the ribbon just to create my path then I have to cycle it again to select my profile then I have to cycle it again to accept and close the sweep command. then whatever the next command is I have to cycle it again to get the proper options.
I have not updated Revit recently, it is already up to date. What the hell is going on?
I am trying to fill out a report request for this issue and the **** support form keeps telling me I have to provide a product. I have provided a product in every way of describing it and it will not accept it. What the hell!
I did manage to send a support request for this and it turns out it was a Microsoft NET issue. I had recently installed Visual studio 11 which installed .NET 4.5 beta on the Friday before this problem started.
At the suggestion of Product Support Specialist David Dembkoski I uninstalled Microsoft .NET and reinstalled .NET 4.
I repaired Revit through programs and features and it fixed the issue.
Thank you Autodesk technical support for providing a solution.
I have just verified that this is also a problem with the released version of .NET Framework 4.5. I fixed it the same way you did.
Thanks for figuring this out, Mine started after I installed Building Design Suite 14 which installs NET 4.5. It has been driving me bonkers since then.
Autodesk has released a hotfix for Revit 2012 that resolves this issue for my company. Here's the link, if you're interested.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=21344242&linkID=12828318
I forgot to mention, that I am using BDS2013, will this Revit 2012 fix work for 2013?
We have found that the latest update to Revit 2013 (Revit 2013 UR2) resolves this issue.
