strange ribbon behavior
8 REPLIES 8
Message 1 of 9
DParkGForce
889 Views, 8 Replies
This is a little hard to explain but the last week or so the ribbon has been acting strange. One example is when creating a sweep the ribbon will not show the mode options to accept or discard changes while creating the sweep path. I have to cycle the ribbon display options to show the X and check options to complete the sweep path. This is only one example of many different odd things happening.
Sometimes when I am simply drawing model lines the selection options for rectangle, circle etc do not appear until I cycle the ribbon display options. This only started in the last week or two.
I will post some screen shots of the problem.
Has anyone else experienced this?
Windows 7
RAC2012
8 REPLIES 8
Message 2 of 9
DParkGForce
in reply to: DParkGForce
OK this is driving me freaking crazy. The ribbon is not switching options at all untill I cycle it. I have to cycle the ribbon display at every step of a command. Making a sweep means I have to cycle the ribbon just to create my path then I have to cycle it again to select my profile then I have to cycle it again to accept and close the sweep command. then whatever the next command is I have to cycle it again to get the proper options.
I have not updated Revit recently, it is already up to date. What the hell is going on?
Windows 7
RAC2012
Message 3 of 9
DParkGForce
I am trying to fill out a report request for this issue and the **** support form keeps telling me I have to provide a product. I have provided a product in every way of describing it and it will not accept it. What the hell!
Windows 7
RAC2012
Message 4 of 9
DParkGForce
I did manage to send a support request for this and it turns out it was a Microsoft NET issue. I had recently installed Visual studio 11 which installed .NET 4.5 beta on the Friday before this problem started.
At the suggestion of Product Support Specialist David Dembkoski I uninstalled Microsoft .NET and reinstalled .NET 4.
I repaired Revit through programs and features and it fixed the issue.
Thank you Autodesk technical support for providing a solution.
Windows 7
RAC2012
Message 5 of 9
joespiff
I have just verified that this is also a problem with the released version of .NET Framework 4.5.  I fixed it the same way you did.
Message 6 of 9
squid44th
in reply to: joespiff
Thanks for figuring this out, Mine started after I installed Building Design Suite 14 which installs NET 4.5.  It has been driving me bonkers since then.
Message 7 of 9
joespiff
Autodesk has released a hotfix for Revit 2012 that resolves this issue for my company.  Here's the link, if you're interested.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=21344242&linkID=12828318
Message 8 of 9
squid44th
I forgot to mention, that I am using BDS2013, will this Revit 2012 fix work for 2013?
Message 9 of 9
joespiff
We have found that the latest update to Revit 2013 (Revit 2013 UR2) resolves this issue.
