Strange dark shadows on Render
3 REPLIES 3
dianeb_acs365
873 Views, 3 Replies
Im new to revit architecture 2013 and am designing office interiors.
Many of the models I use are downloaded from manufacture websites which are a mixture of 3ds and dwg files. I import these into sketch up to remove any material off them as otherwise I have issues applying revit textures.
However, now when I render these blocks have random dark shadows on them, triangles than don't match with the light source. I export from sketch up as a 2007 dwg file and import the cad file straight into revit project. Realistic viewport looks correct but render is effected by random shadows. The same block in a project has different shadows as if it is being effected by the light?
Any ideas?
Many thanks, Diane
3 REPLIES 3
Yeh, I'm happy enough with the image. It's the triangle shape shadows that appear on some of the CAD blocks that look really wrong. I have to then photoshop the image to get rid of these dark lines.
Is this caused From using sketchup to convert the model or is there a setting I can change.
The pedestals Shouldn't have them lines on it.
