Still Nothing with Rails!!!
3 REPLIES 3
183 Views, 3 Replies
I cant create any railing profile, I guess there is something I dont read or type correctly. Please help... I send a file with one of my failures. Thank you all for your time. Dimitris
3 REPLIES 3
Dimitris, If the baluster is not designed to be used on stairs (or to change their angle with stairs) then it is best to either disable (or delete) the "Top Cut Angle" parameter or set it to zero before crating geometry. Attached is your FIXED baluste. -- Regards, Steve Burri Autodesk, Inc Client Support Manager - Revit -------------------------------------------------------------------------------- "JTB" wrote in message news:4128c649_1@newsprd01... > I cant create any railing profile, I guess there is something I dont read or > type correctly. > Please help... > > I send a file with one of my failures. > > Thank you all for your time. > > Dimitris > > > Attachment not added (content type not allowed): "JTB-BALUSTER-XIASTO-FIXED.rfa"
Here's a zipped version of the file... "Steve Burri" wrote in message news:4129408f_2@newsprd01... Dimitris, If the baluster is not designed to be used on stairs (or to change their angle with stairs) then it is best to either disable (or delete) the "Top Cut Angle" parameter or set it to zero before crating geometry. Attached is your FIXED baluste. -- Regards, Steve Burri Autodesk, Inc Client Support Manager - Revit ------------------------------------------------------------------------------ "JTB" wrote in message news:4128c649_1@newsprd01... > I cant create any railing profile, I guess there is something I dont read or > type correctly. > Please help... > > I send a file with one of my failures. > > Thank you all for your time. > > Dimitris > > >
Thank you very much, I guess it was the cutting angle...
