Startup problem with Revit.
4 REPLIES 4
313 Views, 4 Replies
I return from 1 customer where I installed AutoCAD Revit Architecture Suite 2010 on 3 computers. The installation went smoothly but Revit does only one job. As soon as I open it, or it stops, or I have a message "Revit has encountered 1 problem ...", or it starts and then displays" No response "in the Task Manager. The 2 computers who have problem have just been upgraded in RAM to go to 2GB.
Have you ever encountered this problem?
Thanks in advance for your help.
4 REPLIES 4
What operating systems are on the machines? Did you also install the Revit
2010 update?
wrote in message
news:6241247@discussion.autodesk.com...
Alfredo_Medina
Try this:
From Windows' desktop: > right click > Properties > Settings tab > Advanced button > Troubleshoot tab > Move the Hardware acceleration slider all to the left. > OK to finish. > Enjoy Revit without crashes.
Alfredo Medina
alfmedina@hotmail.com
Licensed Architect (Florida) | Freelance Instructor | Autodesk Expert Elite (on Revit) | Profile on Linkedin
The client use Windows XP pro.
For the solution, I will ask to the client to try this solution.
Best regards.
GL
Make sure your video drivers are 100% up to date - even one release behind in your drivers can make a big difference
