One of the problems that the Revit version 2013 and 2014 is created in this step is:
When the tool is used and the Stait by componnt file will be exported to Autodesk 3ds Max Design is quite clear that the two are drawn to each other on the stairs.. There are always two on each step.
I think this is a very big problem that is likely in view of the large errors can be estimated Cost
This problem is visible in the Revit software environment, but are individually selected in Revit.
For example, if an element in Revit you can choose the color of the selected element will display perfectly
But when we Stait by componnt choose to paint only the edges of the selected element is displayed
Does anyone accept this problem is?
Please advise if a solution comes to mind.
Please see the pictures below.
Thank
revit file:
FBX in max:
The new version of Revit, I think the new elements are not compatible with FBX format.
Once the FBX file format into 3D Max design software, additional elements are shown on page 3 D Max Design especially doors and windows.
These elements are clean and are not just performing.
Hi
Who has not found the solution to this problem.
