I have a client that needed to know the distence required to make a stair case, and when I drew it wight revit 2013, I descovered that I could manualy adjust the riser hight but was unable to adjust the tread length. I was also unable to end the stairs with a tread rather than a riser, witch he wanted. Can these be fixed in 2014?????
Richard Widman
Ace Design Drafting
For the treads, you need to specify the mimimum depth in the properties of the stair. Or, you could draw the risers manually, with the desired depth as offset, with the riser tool. About ending with riser or thread, that is also an option in the properties of the stair.
