stairs and floor slabs
5 REPLIES 5
donied
2003 Views, 5 Replies
Is it possible to get the stairs to cut a hole in the above floor slab in Revit. So I know that the head height is correct
5 REPLIES 5
vector2
in reply to: donied
funny thing about stairs- (well not
funny really)- is that they are not only
complex- but how you build them
depends on the local building code
requirements.
to make things easier you probably
need to create stair types with all
the parameters and rules that fit
your local requirements and then
have that in your template..
as for the stairs cutting a hole in
the floor above- just tell it what
floor to go up to and then cut
whatever hole around the stairs
you want..
but that might not be what you
want to know see my image attached.. Edited by: Discussion_Admin on Jan 23, 2010 12:25 PM
parveensharma2130
in reply to: donied
you need to edit the floor manually. Then you can cut a section to see the clear head height.
Stairs in revit does not cut the floor automatically.
in reply to: donied
You can also use a shaft object if you need to cut many floors at one time
in the same shape. This may be faster than editing each floor individually.
Jeff Hanson
SME (Subject Matter Expert)
Autodesk - BIM UX
Manchester, NH
wrote in message news:6323390@discussion.autodesk.com...
clear head height.
donied
in reply to: donied
Thanks. The shaft option solved my problem
alicata
That was exactly what I was wondering! Thanks.
