How can I get the tread side edge or profile (not nosing) to extend over the stringer or recess the stringer under the tread. See photo. Revit 2010
Thanks.
Solved by constantin.stroescu. Go to Solution.
Your Name
Thank you. I thought I tried all combinations of setting in there. Must have missed that one.
Is there a way to keep the riser and have the stringer move up/down in relation to the nosing of the stair? I need to move the stringer, but keep the riser (stairs must be a continuous piece, for safety).
I am trying to get a carriage (open) stringer to be proud of the treads. In a closed stringer, the treads are located to the inside of the stringer, how can I do this with a carriage stringer? I have searched through all the options, and cannot seem to find the correct settings. Thank you! I am using Revit 2018.3
