I am trying to create a simple L shaped staircase with a landing. The problem is that when I finish the stair, there is a large gap between the stair landing and the skirt board for the 2nd flight of stairs. Attached is a pdf showing my problem. Any suggestions.
Justin Honey
Pittsburg State University
There might be a problem with the nosing profile and its settings. Hard to tell without looking at the .rvt file.
I used the "stock" stairs straight out of the box. I selected open both sides. The only thing I changed was the tread depth and the riser height. Everything else stayed the same. I tried to attach the file, but it says it is too large to post. I would appreciate any help I can get.
You could try pulling the last riser of the first flight away from the corner by 1/2" (or whatever the little distance is where the error is occuring. Might see if that resolves the issue.
