How can I extend Tread below the riser, I have attached a picture for explanation , the Autocad illustration is what I want, The Revit three D model is what I have, What Should I change to achieve the AutoCAD illustration.
Solved by mike. Go to Solution.
Thanks for your reply, I already tried that, but I don't get that result. I get the same using underside of winder as smooth and stepped as well.
thanks
In the stair proerties dialogue box there is an option to "extend tread under riser" which may help. Or could you set the riser thickness to be 0.18 ?
