I am having difficulty getting right number of risers with the riser height to work. I have a 9'-0" floor to floor height. We would like to use 14 risers at 7 3/4". When I select 14 risers in the stair properties I get a riser height of 7 183/256" which does not equal 9'-0" (I checked with a calculator). It comes up short so the actual number of risers change to 15. I cannot manually change the riser height. Am i missing something?
Also what is with this "you need no more than two bounderies" error I get everytime I draw stairs. I have multiple landings between these two floors so there will be more than two bounderies.
Kory Skoog
Kory Skoog
PM/BIM Manager
