Please tell me How to set up this kind of stair railings? See attached.
Willie
I created a short video (no audio) showing how this can be done. Using the railing from the default template, you first need to edit the type and add a 2nd rail near the bottom. Then edit the baluster pattern. The bausters are first set to stop at the lower rail created in the previous steps. Then a pattern is defined by duplicating the baluster until the pattern is 4' long. Then the last baluster in the pattern is changed so it goes down to the host stair. finally the pattern is told to truncate so it will fill in if you do not have a stair that accomodates the exact spacing needed.
The word video is a hyperlink in my previous post. Just click it to go to the video, or use this direct link.
