Neal,
Since Revit does not allow more than two chains of segments for the stair boundaries,you have to do this in two pieces. Once you are finished, you can convert the two pieces into one by creating a group. The two pieces are these: one that is an 'L' shape, going from the bottom to the top, let's say from Level 1 to Level 2, with the fancy first two steps and all that. The second part is just a flight that goes from the landing of the 'L' shape to Level 2. To do that second part, you need to go into the stairs properties dialog box and specify a certain base offset value (the landing height) and also specify Level 2 as the top offset. Then, for the L part, you need to edit the railing on the side that receives the small flight, so that people can go up and down from either side.
Alfredo Medina
Planta1.com
Online training of
AutoCAD Revit Architecture Suite
Licensed Architect (Florida) | Freelance Instructor | Autodesk Expert Elite (on Revit) | Profile on Linkedin
