Stair landing
3 REPLIES 3
825 Views, 3 Replies
Stair landing
When using the stair run option(2010) is it possible to start the stair run with a landing, and not have the stair run immediatly start with steps??
3 REPLIES 3
Do the sketch as you normally would, then move the first riser line to increase the depth of the first tread to make it a landing.
thanks for reply
OK, i moved the first riser line, which created the landing- the stringers do not follow underneath the landing-isi there a setting to have stringers under landing also?
You need to split the boundary lines on both sides, to separate them in two segments. The longer segments will be sloped, (the rest of the risers). The shorter segments (the landing) should be specified as Flat.
