stair landing top & bottom
5 REPLIES 5
haydenwse
4777 Views, 5 Replies
I can make a flight of stairs with a landing at the top but how do you make one that begins with a landing?  My stair structcure depth is 6", the rise is 7" and the landings are 8".  If I streching the first tread to make the landing it is only 7" (the height of the rise).  How do i make an 8" landing to begin a stair?
5 REPLIES 5
I am not sure I understood you well...is that what you want?
Constantin Stroescu
BIM Manager AGD
haydenwse
in reply to: haydenwse
here is a screen shot of a work-around that i have come up with.  I bured an extra step at "riser depth below the landing elevation.  then I created a landing with a floor element.  it sort of works but I get a duplication of volume and the stair and landing concrete show up in different materilal scheduls.  it also makes the 3d views have a shadow step in the landing.
in reply to: constantin.stroescu
constantin.stroescu:
How can i join the stair with the slab? Did you used a workaround?
constantin.stroescu
no workaround...
I worked on R 2014
Architecure >Stair>Stair by Component.
Work in section view. Select the stair. Geometry >Join. Stair concrete structure will join the core of the slab...
you can also edit Stair by Component in section view:
If in section view you select the stair and then : Edit > Edit Stairs > click again on stair and Drag the round blue point from upstair ( or downstair) the height of the stair will change but not the slope. Draging the arrow blue point will keep the height but change the slope...
Constantin Stroescu
BIM Manager AGD
Thank you very much.
Rail Community
