Hey guys,
I have drawn these stairs with sketch as they have winders in them. The cut line is way off and cant seem to change it. When I try and chamge the cut line angle nothing happens just stays the same. Anyone know how to fix this? Cheers.
Solved by arunag. Go to Solution.
hi, can you post some part of it to check. thanks
Please see attached file. Reduced it as much as I could. Thanks.
Give any angle greater than 110, it will work check this image as to why 110
