I am currently having trouble with astaircase design. I have a stair that at the base is 3 sided. I currently modekled it as 4 seperate stairs and would like it to be just one. I am having trouble and maybe its my nose profile with wrapping around corners.
Also when I try and edit a stair to make it two sided it starts to facet the edge??? Any suggentions would be very helpfull.
Can you please send me your Stair Design profile??? I can try my best at my end.
Thanks & regards,
Subhradeep Sen
Kolkata
India
Hi all, this issue is for monolithic stair only, the problem is that Revit makes the bottom of the stair from the point to the left with the point at the wright of the stair not considering the square form of it. You should make the stringer carriage height greater or make the stair with wood stair and change the materials, because with this type of stair it does not happen.
I hope this will be helpfull. Alex
