Staggered Section
2 REPLIES 2
717 Views, 2 Replies
Staggered Section
Does Revit allow you to create a staggered section?
2 REPLIES 2
No, not directly, but you can create a staggered section (some limitations) quite effectively. How you ask? You create two sections , each one representing the different positions (stagger) you want to show, then combine those two views on a sheet. Use the crop regions in the View Properties to adjust the images to align alongside each other. -- Mel Persin, Architect-AIA Network/CAD Consultant, Support & Training "Amer Ismail" wrote in message news:4003096d$1_3@statler... > Does Revit allow you to create a staggered section? > >
Here's a graphical, step-by-step version of Mel's answer... Is it possible to create an Offset Section? -- Regards, Steve Burri Autodesk, Inc. Client Support Manager - Revit "Mel Persin" wrote in message news:4003cb29_1@statler... > No, not directly, but you can create a staggered section (some limitations) > quite effectively. > > How you ask? You create two sections , each one representing the different > positions (stagger) you want to show, then combine those two views on a > sheet. Use the crop regions in the View Properties to adjust the images to > align alongside each other. > > -- > Mel Persin, Architect-AIA > Network/CAD Consultant, > Support & Training > > "Amer Ismail" wrote in message > news:4003096d$1_3@statler... > > Does Revit allow you to create a staggered section? > > > > > >
