Square cut rafters?
4 REPLIES 4
2739 Views, 4 Replies
Square cut rafters?
I can't seem to get a roof to have square cut rafters in 6.0. The roof properties allow for 3 options: Plumb cut - vertical roof edge 2 cut square - horizontal roof edge - THAT looks wierd 2 cut plumb - same thing as 2 cut square Is this a defect, or is there some other way to have a square cut fascia (other than applying a sweep to the edge of the roof)? -- Matt Dillon Enceptia, Inc. http://www.enceptia.com
4 REPLIES 4
You need to change your option to 2 Cut Square and then give it a large fascia depth. 2 Cut Plumb and 2 Cut Square are not the same. "Matt Dillon" wrote in message news:403e27ac$1_2@newsprd01... > I can't seem to get a roof to have square cut rafters in 6.0. The roof > properties allow for 3 options: > > Plumb cut - vertical roof edge > 2 cut square - horizontal roof edge - THAT looks wierd > 2 cut plumb - same thing as 2 cut square > > Is this a defect, or is there some other way to have a square cut fascia > (other than applying a sweep to the edge of the roof)? > > -- > Matt Dillon > Enceptia, Inc. > http://www.enceptia.com > > >
OK, cool - that did it. Thanks. Can you tell me WHY the fascia depth even matters? Just curious. -- Matt Dillon Enceptia, Inc. http://www.enceptia.com "Greg Cashen" wrote in message news:403e351c$1_2@newsprd01... > You need to change your option to 2 Cut Square and then give it a large > fascia depth. 2 Cut Plumb and 2 Cut Square are not the same. > > > "Matt Dillon" wrote in message > news:403e27ac$1_2@newsprd01... > > I can't seem to get a roof to have square cut rafters in 6.0. The roof > > properties allow for 3 options: > > > > Plumb cut - vertical roof edge > > 2 cut square - horizontal roof edge - THAT looks wierd > > 2 cut plumb - same thing as 2 cut square > > > > Is this a defect, or is there some other way to have a square cut fascia > > (other than applying a sweep to the edge of the roof)? > > > > -- > > Matt Dillon > > Enceptia, Inc. > > http://www.enceptia.com > > > > > > > >
Because you can have a two cut fascia and the dimensions of the two cuts will change based on the depth of the fascia...for instance, if you want to put a gutter on the fascia, you will need at least 4.5 inches of plumb fascia to have it attach flush with the bottom. But you could also go for 5.5 inches or whatever you like.There is an infinite combination of fascia to cut depth ratios and not everyone does them the same. "Matt Dillon" wrote in message news:403e65af$1_2@newsprd01... > OK, cool - that did it. Thanks. > > Can you tell me WHY the fascia depth even matters? Just curious. > > -- > Matt Dillon > Enceptia, Inc. > http://www.enceptia.com > > > "Greg Cashen" wrote in message > news:403e351c$1_2@newsprd01... > > You need to change your option to 2 Cut Square and then give it a large > > fascia depth. 2 Cut Plumb and 2 Cut Square are not the same. > > > > > > "Matt Dillon" wrote in message > > news:403e27ac$1_2@newsprd01... > > > I can't seem to get a roof to have square cut rafters in 6.0. The roof > > > properties allow for 3 options: > > > > > > Plumb cut - vertical roof edge > > > 2 cut square - horizontal roof edge - THAT looks wierd > > > 2 cut plumb - same thing as 2 cut square > > > > > > Is this a defect, or is there some other way to have a square cut fascia > > > (other than applying a sweep to the edge of the roof)? > > > > > > -- > > > Matt Dillon > > > Enceptia, Inc. > > > http://www.enceptia.com > > > > > > > > > > > > > > >
OK... got it. Crystal clear now. Thanks. -- Matt Dillon Enceptia, Inc. http://www.enceptia.com "Greg Cashen" wrote in message news:403e6f51$1_2@newsprd01... > Because you can have a two cut fascia and the dimensions of the two cuts > will change based on the depth of the fascia...for instance, if you want to > put a gutter on the fascia, you will need at least 4.5 inches of plumb > fascia to have it attach flush with the bottom. But you could also go for > 5.5 inches or whatever you like.There is an infinite combination of fascia > to cut depth ratios and not everyone does them the same. > > > "Matt Dillon" wrote in message > news:403e65af$1_2@newsprd01... > > OK, cool - that did it. Thanks. > > > > Can you tell me WHY the fascia depth even matters? Just curious. > > > > -- > > Matt Dillon > > Enceptia, Inc. > > http://www.enceptia.com > > > > > > "Greg Cashen" wrote in message > > news:403e351c$1_2@newsprd01... > > > You need to change your option to 2 Cut Square and then give it a large > > > fascia depth. 2 Cut Plumb and 2 Cut Square are not the same. > > > > > > > > > "Matt Dillon" wrote in message > > > news:403e27ac$1_2@newsprd01... > > > > I can't seem to get a roof to have square cut rafters in 6.0. The roof > > > > properties allow for 3 options: > > > > > > > > Plumb cut - vertical roof edge > > > > 2 cut square - horizontal roof edge - THAT looks wierd > > > > 2 cut plumb - same thing as 2 cut square > > > > > > > > Is this a defect, or is there some other way to have a square cut > fascia > > > > (other than applying a sweep to the edge of the roof)? > > > > > > > > -- > > > > Matt Dillon > > > > Enceptia, Inc. > > > > http://www.enceptia.com > > > > > > > > > > > > > > > > > > > > > > > >
