Revit Architecture
Valued Contributor
nikana2000
Message 1 of 11 (1,498 Views)
Spot Slope for Ramps
1498 Views, 10 Replies
11-23-2012 08:27 AM
Is there a reason 'Spot Slope' works for floor slabs, but not ramps (in section)?
Is there a work-around to have slopes notated for ramps?
Thank you in advance
Alfredo_Medina
Message 2 of 11 (1,491 Views)
Re: Spot Slope for Ramps
11-23-2012 10:24 AM in reply to: nikana2000
See this other thread:
http://forums.autodesk.com/t5/Autodesk-Revit-Architecture/Spot-Level-Problem/m-p/3571680#M62005
Planta1 Revit Online Consulting | info@planta1.com | my Twitter | The Planta1 Blog
Valued Contributor
nikana2000
Message 3 of 11 (1,481 Views)
11-23-2012 12:52 PM in reply to: Alfredo_Medina
Thank you for the response Alfredo, however I'm looking for a spot "slope", not "elevation" or level.
I've attached a photo showing the difference.
/using 2013
Alfredo_Medina
Message 4 of 11 (1,471 Views)
11-23-2012 01:35 PM in reply to: nikana2000
Spot slope works for ramps in section. (At least here, Revit 2013). The issue happens in the floor plan view, and the same trick "works" in that case, too.
Valued Contributor
nikana2000
Message 5 of 11 (1,406 Views)
11-26-2012 12:43 PM in reply to: Alfredo_Medina
I tried again Alfredo in a separate/new file, and am unable to have 'spot slope' for ramps in section.
I even drew the ramp exactly perpendicular to the section line.
Active Contributor
sagar.londonites
Message 6 of 11 (1,355 Views)
11-30-2012 08:56 PM in reply to: nikana2000
Go to a 3D view, align it to Top mode so that you can see the ramp just like in a Plan view.
You'll now be able to add a spot slope to the ramp. Copy the spot slope, go to the Plan view, 'Paste to Current View'. Done!
- Sagar
Valued Contributor
nikana2000
Message 7 of 11 (1,317 Views)
12-05-2012 01:39 PM in reply to: sagar.londonites
Thank you Sagar, but that does not work for me either.  (see attached screencapture for error message)
Also, I require the 'spot slope' for a section, not plan.
Alfredo_Medina
Message 8 of 11 (1,311 Views)
12-05-2012 01:44 PM in reply to: nikana2000
Spot slope on ramps works fine for me in elevation or section view (Revit 2013). In plan, it still has that "bug" which can be "fixed" by placing the spot slope first on a floor and then moving the spot slope to the ramp.
Valued Contributor
nikana2000
Message 9 of 11 (1,301 Views)
12-05-2012 04:09 PM in reply to: Alfredo_Medina
Digging into the issue deeper, I can get a spot slope in section only if the ramp has a railing (which the slope is not related to the ramp).
I thought I'd try this from a new project created from a standard 'Architectural' template, but received the same results as above.  It is attached.
Are you able to place a a spot slope in section to the ramp without rails?
/Edit: Not letting me attach the 880kb RVT file
Alfredo_Medina
Message 10 of 11 (1,295 Views)
12-05-2012 04:19 PM in reply to: nikana2000
Yes, without rails, or with rails.
