SPOT ELEVATION TAGS
1 REPLY 1
247 Views, 1 Reply
SPOT ELEVATION TAGS
Is it possible to add formulas to spot elevation tags in plan? eg. When I place a tag in plan, I want it to display x level ie. x = actual level - y value Thanks John
1 REPLY 1
You can't do that. Spot elevation is essentially a dimension that measures an elevation coordinate of an object it is pointing to. Why do you want to do it? What is the underlying intent? "John" wrote in message news:41a6dd5e_2@newsprd01... > Is it possible to add formulas to spot elevation tags in plan? > > eg. When I place a tag in plan, I want it to display x level ie. x = > actual > level - y value > > > Thanks > > John > >
