Hello all,
One of my colleagues was able to insert Spot Elevations by picking anywhere on the surface of his floor objects in his floor plan yesterday (2013 Central file with two users working). Today, when he tries to place the same Spot Elevation object, he is only able to pick the floors at the perimeter of the floor objects instead of the surface of the floor. Any thoughts on what setting or mode they accidentally changed to prompt this unfortunate behavior?
Solved by ChrisNeedhamNZ. Go to Solution.
I'm guessing that the view may have been changed to wireframe. Set it back to hidden line if that is the case.
You were spot on. Lesson learned.
Thanks very much for your expertise Chris.
Scott
