Spot elevation doesn’t’ take the correct measurement,
I tried to add the “spot elevation” for the stair plan but sounds not to take the correct value.
What might be the reason?
Thank you
Best
Jamal
Solved by CoreyDaun. Go to Solution.
There are a couple of parameters that control the reported elevation (see image), have you checked these settings?
Many thanks for the help CADastrophe. It does work.
Your screenshot is a good “road map” for the solution
Best
Jamal
