Splitting model into separate files
3 REPLIES 3
Piestar
2437 Views, 3 Replies
We're splitting a big (not oversized) model into 3 in order to send to different companies for tender.
The reason for splitting is to ensure privacy for the other areas they don't need to know about.
Could someone suggest the best method to seperate model, views, sheets, tags, basically everything.
[ Piestar // Interested in all things Revit & BIM ]
3 REPLIES 3
K_R_Venkat
in reply to: Piestar
Have u tried with "Group"? if not try to make group and save as a Separate (Clipped) .rvt file.
STEPS
First Select all the elements, "Create Group" with specifc Name.
And locate that same Group in the Project Browser under Group->Model, Select it, Right Click and "save Group".
That will give u a separate .rvt File.
Hope this will help u.
Venkat.PR
Piestar
in reply to: K_R_Venkat
In the end I decided to create a load of different projects based on the original - then delete what I didn't want in each one!
Maybe a bit controversial but it worked.
Thanks for the reply anyway.
damo3
As long as its not a regular process i guess. What happens if they know about it?
________________________________________________________________________________
If you find posts have solved your problem, please don't forget to mark them as 'SOLVED' to help others with similar questions. - Thank you.
__________________________________________________________________________________
